Gearbox Breather?
ukmatador
Yes to the L/H if its the same has the trials bikes they some times get blocked just blow it out with a Air line or spoke a bit off wire throw make sure you don't drop the wire in there.
Edited by bondy
I recall the gearbox breather hole on the Sherpa's (199) been located directly above the kick start shaft and to the left of where the kickstart return spring is "anchored" to the crankcase.
Must try and get a photo when I'm in the garage tomorrow night and post it up.
Edited by model80
  • Like 2
