ukmatador Posted March 4, 2017 Report Share Posted March 4, 2017 1969 MK3 Matador M26 engine. Does the gearbox have a breather, if so where is it? John Quote Link to comment Share on other sites More sharing options...
bondy Posted March 4, 2017 Report Share Posted March 4, 2017 Hi I only have the Bultaco trials if its the same it will be a tiny hole hat the top off the front sprocket to the L/H hope this helps. Quote Link to comment Share on other sites More sharing options...
ukmatador Posted March 5, 2017 Author Report Share Posted March 5, 2017 Hi Do you mean above the gear box sprocket? John Quote Link to comment Share on other sites More sharing options...
bondy Posted March 5, 2017 Report Share Posted March 5, 2017 (edited) Yes to the L/H if its the same has the trials bikes they some times get blocked just blow it out with a Air line or spoke a bit off wire throw make sure you don't drop the wire in there. Edited March 5, 2017 by bondy Quote Link to comment Share on other sites More sharing options...
ukmatador Posted March 5, 2017 Author Report Share Posted March 5, 2017 Thanks. Will have a look this week. John Quote Link to comment Share on other sites More sharing options...
model80 Posted March 5, 2017 Report Share Posted March 5, 2017 (edited) I recall the gearbox breather hole on the Sherpa's (199) been located directly above the kick start shaft and to the left of where the kickstart return spring is "anchored" to the crankcase. Must try and get a photo when I'm in the garage tomorrow night and post it up. Edited March 6, 2017 by model80 2 Quote Link to comment Share on other sites More sharing options...
bondy Posted March 6, 2017 Report Share Posted March 6, 2017 (edited) My fault it is to the top L/H side off the K/Start shaft Edited March 6, 2017 by bondy Quote Link to comment Share on other sites More sharing options...
ukmatador Posted March 8, 2017 Author Report Share Posted March 8, 2017 Found it. Thanks John Quote Link to comment Share on other sites More sharing options...
