heffergm Posted March 8, 2017 Report Share Posted March 8, 2017 (edited) What are you using? The manual on the vertigo site specs a Castrol synthetic ATF (the closest thing I can get in the US is Mobil 1 Synthetic ATF). The US importer seems to recommend a Maxima 0w10 (no idea why). A close US dealer runs regular ATF. Maybe anything vaguely oil like will suffice. Edited March 8, 2017 by heffergm Quote Link to comment Share on other sites More sharing options...
dadof2 Posted March 9, 2017 Report Share Posted March 9, 2017 Maxima 0w 10 is virtually identical to Castrol synthetic ATF. Regular ATF (Rather than the most recent synthetic types) will not provide the same level of protection. Quote Link to comment Share on other sites More sharing options...
copemech Posted March 9, 2017 Report Share Posted March 9, 2017 There are any number of synthetic AFT's available. Try something exotic like Royal Purple or Amzoil. Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 9, 2017 Author Report Share Posted March 9, 2017 Of the synthetic ATF brands I could find spec sheets for, only Mobil 1 had basically the same numbers as the Castrol. I have no idea how (or if) the maxima compares, haven't looked to see if they publish a spec sheet yet. Quote Link to comment Share on other sites More sharing options...
billyt Posted March 9, 2017 Report Share Posted March 9, 2017 (edited) On 3/9/2017 at 12:33 AM, dadof2 said: Maxima 0w 10 is virtually identical to Castrol synthetic ATF. Regular ATF (Rather than the most recent synthetic types) will not provide the same level of protection. Expand How did you come up with a hypothesis that a synthetic fluid engineered for a hydrualic application (automatic transmission) is the same as a synthetic fluid engineered for a gearbox with clutch application? Edited March 9, 2017 by billyt Quote Link to comment Share on other sites More sharing options...
billyt Posted March 9, 2017 Report Share Posted March 9, 2017 On 3/8/2017 at 11:18 PM, heffergm said: What are you using? The manual on the vertigo site specs a Castrol synthetic ATF (the closest thing I can get in the US is Mobil 1 Synthetic ATF). The US importer seems to recommend a Maxima 0w10 (no idea why). A close US dealer runs regular ATF. Maybe anything vaguely oil like will suffice. Expand Because they sell Maxima...... Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 9, 2017 Report Share Posted March 9, 2017 On 3/9/2017 at 1:37 AM, billyt said: How did you come up with a hypothesis that a synthetic fluid engineered for a hydrualic application (automatic transmission) is the same as a synthetic fluid engineered for a gearbox with clutch application? Expand Have you looked inside an automatic gearbox multiple wet clutches with friction material similar to that used on multiplate trials clutches and numerous epicilic gear sets doing much more work than a straight cut trials dog shift box with minimal hp 6 Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 9, 2017 Author Report Share Posted March 9, 2017 Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 9, 2017 Author Report Share Posted March 9, 2017 (edited) On 3/9/2017 at 1:59 AM, billyt said: Because they sell Maxima...... Expand I'm sure they do, but they likely carry all kinds of other oil. But they mentioned it was 'recommended'. By whom I have no idea. Based on the numbers, I'm more inclined to run M1 simply because the viscosity numbers are closer to the Castrol recommended in the manual, and the fact that any additive package in the M1 is going to be more similar to the Castrol, being that they're both ATF. Edited March 9, 2017 by heffergm Quote Link to comment Share on other sites More sharing options...
billyt Posted March 9, 2017 Report Share Posted March 9, 2017 On 3/9/2017 at 7:21 AM, jimmyl said: Have you looked inside an automatic gearbox multiple wet clutches with friction material similar to that used on multiplate trials clutches and numerous epicilic gear sets doing much more work than a straight cut trials dog shift box with minimal hp Expand Yes I have. ATF oil does not has similar charicteristics in the way of shear, foaming, stiction. Amongst other things an automatic transmission uses hydraulic pressure through its passages. Two completely different applications. 1 Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 9, 2017 Author Report Share Posted March 9, 2017 (edited) I have no idea what you guys are arguing about at this point... The Vertigo manual specs ATF fluid. I'm fine with that. Edited March 9, 2017 by heffergm Quote Link to comment Share on other sites More sharing options...
billyt Posted March 9, 2017 Report Share Posted March 9, 2017 On 3/9/2017 at 10:19 AM, heffergm said: I'm sure they do, but they likely carry all kinds of other oil. But they mentioned it was 'recommended'. By whom I have no idea. Based on the numbers, I'm more inclined to run M1 simply because the viscosity numbers are closer to the Castrol recommended in the manual, and the fact that any additive package in the M1 is going to be more similar to the Castrol, being that they're both ATF. Expand I actually asked the same question of LS of why Maxima 0-10W ? I would agree the Mobil 1 ATF is a good substitute. Quote Link to comment Share on other sites More sharing options...
billyt Posted March 9, 2017 Report Share Posted March 9, 2017 ATF - AUTOMATIC TRANSMISSION FLUID As automatic transmissions become more complex, there’s a need for more technologically advanced fluids to ensure vehicle reliability. Getting the right oil for your car is key to ensuring your transmission operates as designed and you get a smooth driving experience every day. Castrol, with over 100 years of experience in developing transmission fluids, and being the choice of many leading car and transmissions manufacturers for factory-fill products, offers a range of automatic transmission fluids for your car’s requirements. Providing you the peace of mind that you are selecting the right oil for your vehicle. TRANSMAX™ FULL SYNTHETIC MULTI-VEHICLE Castrol® Transmax™ Full Synthetic Multi-vehicle is a technologically advanced, low viscosity formulation specially designed to deliver maximum fuel efficiency for modern automatic transmissions. It is blended with premium base stocks and is fully approved by both Ford and GM for use in vehicles requiring their latest ATF specifications. Exceeds requirements of JASO-1A and recommended for a wide range of import vehicles. Product Data Sheet CASTROL® TRANSMAX™ CVT Castrol® Transmax™ CVT is designed for most continuously variable transmissions. Its superior technology enables longer transmission life. Product Data Sheet TRANSMAX™ DEX/MERC ATF Castrol® Transmax™ DEX/MERC includes enhanced friction durability for smooth transmission performance. Designed for use in older Ford and GM vehicles. Product Data Sheet TRANSMAX ATF+4® Castrol® Transmax™ ATF+4® is an advanced full synthetic formulation for superior transmission life. Certified for use in all Chrysler vehicles. Product Data Sheet TRANSMAX™ IMPORT MULTI-VEHICLE Castrol® Transmax™ Import multi-vehicle is for use in most Honda, Toyota, and Nissan vehicles as well as other imported brands. Product Data Sheet TRANSMAX™ HIGH MILEAGE Castrol® Transmax™ High Mileage is ideal for most transmissions with over 75,000 miles. Additional seal conditioners help stop leaks. Extra cleaning agents reduce varnish and deposit formation. Protects against clutch wear and restores smooth shifting. Product Data Sheet TRANSMAX™ MERCON®V Castrol® Transmax™ MERCON®V includes exceptional thermal protection and promotes smooth shifting. Certified for use in Ford vehicles that require Mercon or Mercon V. Product Data Sheet TRANSMAX™ TYPE F Castrol® Transmax™ Type F provides excellent lubrication to gears and bushings, allowing for smooth transmission operation. Certified for use in all Ford vehicles that require Type F ATF. Product Data Sheet TRANSMAX™ DEXRON®VI ATF Castrol® Transmax™ DEXRON®is a premium synthetic blend certified for use in all GM vehicles. Outstanding deposit resistance and enhanced friction durability improve shifting performance. Product Data Sheet Quote Link to comment Share on other sites More sharing options...
heffergm Posted March 9, 2017 Author Report Share Posted March 9, 2017 (edited) Yeah, none of those are Transmax Z though I've looked at the spec sheets of almost all those that seem relevant (Dexron III stuff), and the M1 is still a closer match on all the published numbers. Edited March 9, 2017 by heffergm Quote Link to comment Share on other sites More sharing options...
jimmyl Posted March 9, 2017 Report Share Posted March 9, 2017 On 3/9/2017 at 2:39 PM, billyt said: Yes I have. ATF oil does not has similar charicteristics in the way of shear, foaming, stiction. Amongst other things an automatic transmission uses hydraulic pressure through its passages. Two completely different applications. Expand Yes It can cope with high pressure but gives good frictional properties reference organic friction material to give smooth take up in clutch packs. Quote Link to comment Share on other sites More sharing options...
