Trans oil?
heffergm
I've just been looking at the spec on the rock oil I got with my bike and it dosen't match the
castrol one that's in the manual, the rock oil is also nearly clear so its a pain to see it in the
sight window as the red one that came in the bike you could see a mile away
Lite_Gear_Oil.pdf
For the most part, volume. A car holds several liters. Our bikes generally only hold 400mL or less.
I'm not an automatic gearbox expert, but I'd imagine they also do far less clutch slipping than we generally do, which means a lot less particulates in the oil.
Edited by heffergm
3 hours ago, cascao said:
In cars, ATF oil have to be changed in intervals like 100.000km. Why on motorcycles we have to change it after 100km or less???
ATF usually needs changing at 50K ideally, engine oil at perhaps 10K on a modern car, or 3K on an old one.  Most motorbikes use combined gearbox and engine oil, and have a wet clutch (rather than an automatic gearbox's belts and torque converter, which is a seperate fluid coupling) which means it all gets dirty faster; trials bikes also don't have an oil filter, which is why I can do 4K between oil changes on my Triumph but a fraction of that on the Gasgas.
Modern auto boxes have clutch packs very similar to pre diaphragm trials clutches and epicyclic gear sets very similar to the small gears in trials bikes.
  • Like 2
  • 2 weeks later...
