IRC tyres
stpauls
Do IRC rear tyres still come off the modern Motad-style rims when inflated at very low pressures,  2 - 3 psi?
If so, then why don't the manufacturers make the bead a bit smaller/reduce it's circumference?
  • 3 weeks later...
Yes the revised irc still come off the rim. Multiple rims. We are calling them "i r ceeing you dnf any moment". At 5 to 6 psi the leak slowly and around 3 ish become a bracelet. My dunlop d803gp's have ridden half a loop in sections flat (only on the bottom mind you) just to make their way back to the pits for a repair. I have found the sidewall on the irc to be stiffer not softer.
--Biff
  • Like 2
I'm have tried a new type IRC that isn't supposed to deflate.
Starting pressure on lap 1.   4 psi
Finishing pressure.   3.5 psi
Starting pressure on lap 2.   4 psi
Finishing pressure.   2.5 psi.
This was a rocky two lap road trial. Probably better result than older IRC but still far from acceptable.
I have now given the bead two coats of Tip Top bead sealer to see if it will help.
Lomax road trial on Monday will test it!
--Biff
You are right. They have a stiffer sidewall and softer tread area.
