Montesa Cota 348 recommended oils
Dan94Williams
Hi Dan
There's loads on here about this, but this is my two penneth' worth. I ride a MH349 (same engine, just slightly bigger) and run 10w30 semi synthetic in the clutch and SAE90 in the box. Some people suggest using monograde in the clutch to prevent slip but it'll only slip in the high gears anyway (if it slips at all) and you're unlikely to need them in a trial
Hope that helps
Gavin
1 hour ago, montesamadness said:
Hi Dan
Hope that helps
Gavin
Thanks for your help Gavin!
