drevil Posted March 14, 2017 Report Share Posted March 14, 2017 HI, Can anyone help. I have a 2013 Ossa TR280i and i have notice on the LHS of the bike there are 2 wires not connected and without a connector. Upon closer inspection they appear to be Green and Black and i think they should be connected to the Sensor Gasolina. Can anyone shed some light on the function / location of this. The bike runs fine ! Quote Link to comment Share on other sites More sharing options...
jsp Posted March 14, 2017 Report Share Posted March 14, 2017 (edited) I think there is a level sensor in the tank on the rear brake side near the throttle body, but I think the wires just end up behind the light, you could buy a small light to act as a low level sensor but I dont know how it worked Edited March 14, 2017 by jsp Quote Link to comment Share on other sites More sharing options...
elemetal Posted March 14, 2017 Report Share Posted March 14, 2017 That is exactly what those two wires are for, 2013 and before didn't have the light (as shown). You can run any small bulb or buy the actual one, pretty sure it goes out when the level is low (opposite of normal). Quote Link to comment Share on other sites More sharing options...
ossabc63 Posted March 14, 2017 Report Share Posted March 14, 2017 Thanks elemetal i bought a small green led off of ebay and wired it in using the unused connector end at the head light. But the lights on all the time, if i disconnect the connector at the sensor lights out. Never thought the dummys would wire it backwards, have to drain the tank down to check. ? Quote Link to comment Share on other sites More sharing options...
jsp Posted March 15, 2017 Report Share Posted March 15, 2017 so is the power supply already there ? Ossabc63 can you post a photo of your set up ? Quote Link to comment Share on other sites More sharing options...
lotus54 Posted March 15, 2017 Report Share Posted March 15, 2017 On my 2014 Explorer the light only comes on with low fuel (well, sometimes it comes on even when I have plenty of fuel left,but could be an airlock in upper tank) Quote Link to comment Share on other sites More sharing options...
ossabc63 Posted March 16, 2017 Report Share Posted March 16, 2017 Jsp here is my setup the wire is a female connector with a black wire and a black wire with green tracer. The connector i cut off one of the unused connectors on the factory harness. Solder and shrink tube to the led light. Quote Link to comment Share on other sites More sharing options...
jsp Posted March 16, 2017 Report Share Posted March 16, 2017 brilliant thanks Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 16, 2017 Report Share Posted March 16, 2017 On 3/14/2017 at 7:58 PM, ossabc63 said: Thanks elemetal i bought a small green led off of ebay and wired it in using the unused connector end at the head light. But the lights on all the time, if i disconnect the connector at the sensor lights out. Never thought the dummys would wire it backwards, have to drain the tank down to check. ? If you reverse the wires does the light go out? Also, are you in BC? looks like you have a Factory R, not many of those around in Canada Quote Link to comment Share on other sites More sharing options...
ossabc63 Posted March 16, 2017 Report Share Posted March 16, 2017 Canada280 iam in the okanagan bc i pm you in dec. the only wires that would be backwards would be my led which wouldnt make a difference. Bikes apart now lubing linkage and had a bad wheel bearing. Then will try sucking out some fuel to see if light goes out. ? Quote Link to comment Share on other sites More sharing options...
drevil Posted March 16, 2017 Author Report Share Posted March 16, 2017 Thanks for all the input it turns out there is no Sensor fitted to my tank. Also does anyone have a spare data cable they want to sell? Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 16, 2017 Report Share Posted March 16, 2017 39 minutes ago, ossabc63 said: Canada280 iam in the okanagan bc i pm you in dec. the only wires that would be backwards would be my led which wouldnt make a difference. Bikes apart now lubing linkage and had a bad wheel bearing. Then will try sucking out some fuel to see if light goes out. ? sorry, yes, I remember you now, how is the bike running? Quote Link to comment Share on other sites More sharing options...
ossabc63 Posted March 17, 2017 Report Share Posted March 17, 2017 Canada280i only ridden it five times last year, ran ok like the bike still getting the starting down. Wired in and got a energizer lithium 9volt like you have. Do you kick yours over just after top dead centre any tricks. Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 17, 2017 Report Share Posted March 17, 2017 No real tricks, from cold I give it a couple of kicks holding the battery button down, the fuel pump can be heard, and then on the third kick it always fires right up. I am experimenting at the moment with a slightly retarded timing set up at the hall sensor, seems to make the engine smoother and very difficult to stall . First real test next weekend so I'll let you know any improvements or not Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 17, 2017 Report Share Posted March 17, 2017 (edited) If i recall that bike had a flywheel weight on it like mine, which in combo with the timing mod does seem to help Edited March 17, 2017 by canada280i Quote Link to comment Share on other sites More sharing options...
