rev3guy Posted January 19, 2004 Report Share Posted January 19, 2004 Hi All, I have a 01 250 rev3, anyone have the torque specs? Most interested in motor case bolts, cylinder, etc. If you can post a link, I am sure all would be very thankful, including me self. Cheers Quote Link to comment Share on other sites More sharing options...
viking Posted January 19, 2004 Report Share Posted January 19, 2004 Tightening torque Rev3: Shock absorber-Swingarm 45Nm Shock absorber-Frame 45Nm Connecting frame rod-frame 23 Nm Cylinder-Crankcase 20-23 Nm Primary drive gear 120 Nm Handlebar 25 Nm Engine-frame 50 Nm Swingarm bolt 90 Nm Front wheel axle 65 Nm Rear wheel axle 65 Nm Steering stern bracket 25 Nm Rear fender bracket 10-15 Nm Front brake pad 20-23 Nm Rear brake pad 20-23 Nm Engine Head-Cylinder nuts 15-16 Nm Front axle fixing nuts 10 Nm Flywheel 140 Nm 1 Nm=0,1 kgm Quote Link to comment Share on other sites More sharing options...
rev3guy Posted January 19, 2004 Author Report Share Posted January 19, 2004 Viking, thank you... Quote Link to comment Share on other sites More sharing options...
