Txt Pro 2004 No Spark Need Testing Values
sw74gls
Hi I have a Txt Pro 2004 with no spark issue and would really appreciate your help/info PLEASE!!!
Here is what I have tested so far with the results:-
* Plug = 4.03K (BPR5ES NGK).
* All Earth Connectors & Coil cleaned plus Frame Bracket.
* Coil Primary Circuit (both wires on unit) = 0.90 ohms.
* Coil Secondary Circuit (spark plug cap) = 5.04k.
* Disconnected Kill Switch wire from Earth/frame/Coil (the white from CDI to black/white on kill switch still connected)
* Pickup Coil Red & Green wires (on stator side plug not CDI)= 94 ohms.
I need help where to go now and what values I should be getting? or if the values on my coil, spark plug/cap, pickup coil are correct or not?
Also I do not have the specific Txt Pro Kokusan Denki 2004 Wiring Diagram so instead  using the txt pro 2002 which is very similar I would really appreciate it if any one could supply a picture/image for me please?
Here is the txt pro 2002 I am currently following attached below:-
Once again sorry for boring the pants off you but I would really really appreciate all your help guys as my head is very sore, thank you so much in advance,
Simon.......
