markg Posted March 20, 2017 Report Share Posted March 20, 2017 Hi all, anyone replaced the carb on an RTL and had success? - what type of carb was used and where would it be available? My RTL carb slide sticks even though the retaining nuts are a bit over finger tight. Gets worse if any tighter. Any suggestions on a fix or carb replacement greatly appreciated. Mark. Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted March 21, 2017 Report Share Posted March 21, 2017 Hey Mark, Great ride on Sunday. Maybe this will help with your RTL carb. I had a similar acting slide on one of my old Honda’s. On close inspection I saw that the index pin had worn and galled up the groove in the slide. Some very careful work with a set of jeweler’s files smoothed up both the pin and the groove in the slide. I followed that up with some polishing compound (toothpaste) on the slide and moved the slide up and down with my finger until it was polished. A good cleaning and it works better than new. Quote Link to comment Share on other sites More sharing options...
barfy Posted March 22, 2017 Report Share Posted March 22, 2017 I tried a flat sided Keihin carb on my RTL but just couldn't get it to run very well. I did notice that the Sherco 4T used a Keihin so posted this thread to see what changes that had: I never tried them deciding to go back to the standard carb but if yours isn't working they might be worth trying. Quote Link to comment Share on other sites More sharing options...
