Water Pump Impeller Question
rvd
Hey guys,
Long time lurker here.   Love the site as it has provided a lot of great info thanks!
Question about my bike.   I just did and overhaul on the waterpump on my 2012 raga,  and have a question about the impeller.
I had to press the assembly out to replace the seal and shaft,  but I think I damaged about half the threads on the impeller being a monkey with it.   I re-assembled,   and I feel like there is still some good bite there.   Until I get a replacement impeller,   would I be foolish to run the bike?   As the impeller is moving water,  and the crank shaft doesn't spin very fast,   I imagine there isn't a lot of force on the impeller.  It felt pretty solid to me still.
Should be good provided a to-spec fit and all the bits are where they should?
Also,  I used 10nM.   does that sound right for torque?
Thanks!
Edited by rvd
You might ask Gas Gas questions under Gas Gas to get a better response. Unfortunately the best video to replace the seal was removed from the internet by stupidity. A screwdriver and an allan wrench was all that was needed. I would fix it proper, as a spinning impellor could cost you in the long run.
On ‎3‎/‎20‎/‎2017 at 6:54 PM, rvd said:
ok guys thanks.    I will swap it out.   are the aluminum billet units of any value?
My wife's Gas Gas is still running fine on its plastic one.  :thumbup:
I haven't ever seen or heard of issues with the plastic ones on Gas Gas.
