diesel2607 Posted March 26, 2017 Report Share Posted March 26, 2017 Can anyone tell me how much I have to remove to get the cylinder barrel off think I am needing to having a look at the rings and condition of things in there Cheers Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted March 27, 2017 Author Report Share Posted March 27, 2017 Thanks for replies my bike had started smoking a bit at my last trial i changed the exhaust packing and at yesterday's trial was OK for about 2 laps then started to smoke very badly I was advised by an experienced rider it looked and sounded like the rings had gone by the smoke trail all along the section I had just ridden and the rattling coming from my bike it's my first bike so no experience with them Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) Rings will not make your bike smoke. Do you have anyone close by that could have a look at the bike before you start tearing into it ? It would be as simple as a build up of oil in the exhaust, and it takes a couple of laps before there is enough heat to burn the oil. Edited March 27, 2017 by b40rt 1 Quote Link to comment Share on other sites More sharing options...
technowaldo Posted March 27, 2017 Report Share Posted March 27, 2017 More likely your crank seal on the clutch side try giving the bike a good roasting to clean it out before you start stripping it Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted March 27, 2017 Author Report Share Posted March 27, 2017 5 hours ago, technowaldo said: More likely your crank seal on the clutch side try giving the bike a good roasting to clean it out before you start stripping it i was also told this today by an experienced rider who saw and smelt the smoke yesterday I have also noticed today that my gearbox oil has also gone so this I believe also points to the crank seal being the problem how hard is the seal to change and any advice for me tackling this job Quote Link to comment Share on other sites More sharing options...
