b40rt Posted April 1, 2017 Report Share Posted April 1, 2017 19 hours ago, bondy said: Had my electronic ignition on 2 years never had a problem bolted straight out the box. Phew, I'll sleep tonight ! Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 1, 2017 Report Share Posted April 1, 2017 I think the engine has suffered some damage it would be super interesting to know what. I believe you have blown the rings and with them everything else touched by them. The bike got too hot to little oil which caused much wear hot blow by and you will need a new top job now. Yes a bad prediction I would be glad if not. Quote Link to comment Share on other sites More sharing options...
netley Posted April 1, 2017 Author Report Share Posted April 1, 2017 I can't really "like" this post as it doesn't bode well. I will report back, but I have an old vfr to finish before I get back to the Bultaco and I'd like to play a little with the Montesa as well. oh what a life I have ! Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 1, 2017 Report Share Posted April 1, 2017 Sorry but as the compression apparently hasn't come back, at least you haven't told so. The chance the engine isn't toast is not high instead the opposite. We might see or read about it ... Surly I wish you luck and will press thumps (if that can help). Looking forward to pic's in the next couple of days. Quote Link to comment Share on other sites More sharing options...
netley Posted April 1, 2017 Author Report Share Posted April 1, 2017 I did say in my first post that when I tried it the next day it had compression and I tentatively tried to start it but it didn't quite catch. I'll try properly on Monday and report back unless you think I shouldn't ??? Quote Link to comment Share on other sites More sharing options...
pschrauber Posted April 1, 2017 Report Share Posted April 1, 2017 Does it feel compression wise like before? You might loan a endoscope there are quite good once with USB hub available these can be plugged to your notebook and do deliver quite good insights. Somikon makse an USB hub endoscope that has a 7m long wire with HD view for under 50€. 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 1, 2017 Report Share Posted April 1, 2017 3 hours ago, netley said: I did say in my first post that when I tried it the next day it had compression and I tentatively tried to start it but it didn't quite catch. I'll try properly on Monday and report back unless you think I shouldn't ??? What's the worst that can happen ? 1 Quote Link to comment Share on other sites More sharing options...
oldjohn Posted April 2, 2017 Report Share Posted April 2, 2017 1 hour ago, b40rt said: What's the worst that can happen ? The bike unexpectedly starts in gear and runs away, throttle wide open. It careens through an outdoor antique fair before crashing into a building where it bursts into flames, burning the orphanage and its occupants to the ground. Lawyers get involved. Apart from that, not much. 8 Quote Link to comment Share on other sites More sharing options...
netley Posted April 2, 2017 Author Report Share Posted April 2, 2017 Well if that's the case old John, I'll give it a go as soon as 2 Quote Link to comment Share on other sites More sharing options...
bondy Posted April 2, 2017 Report Share Posted April 2, 2017 If it was me id just strip the motor down not what you want to hear but at least you will know what the problem is that way you can be sure. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted April 2, 2017 Report Share Posted April 2, 2017 It would be interesting to know what carbie you are running and what size main jet Quote Link to comment Share on other sites More sharing options...
netley Posted April 2, 2017 Author Report Share Posted April 2, 2017 https://www.inmotiontrials.com/product/mikuni-trials-carb-complete/ Bottom end and crank have been re-built. Using original piston, head and barrel. Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted April 3, 2017 Report Share Posted April 3, 2017 I would still take the float bowl off and check the size of the main jet- mistakes happen! 1 Quote Link to comment Share on other sites More sharing options...
spen Posted April 3, 2017 Report Share Posted April 3, 2017 Might be a piston ring issue, end snapped off or something like that......... Quote Link to comment Share on other sites More sharing options...
netley Posted April 7, 2017 Author Report Share Posted April 7, 2017 Says it all really...... I'll pull the head and barrel off during the week, bugger !!! Quote Link to comment Share on other sites More sharing options...
