oldgit Posted April 7, 2017 Report Share Posted April 7, 2017 Hello, I was just visually checking my bike through the 'porthole' this morning and noticed that the oil was a little cloudy. On draining, the oil was a little milky coffee coloured. I've seen quite a few examples of head gasket leaks and the oil was nowhere near as milky as one of those. There were also some small residues which I initially thought might be rubber from a worn-out seal - however, on examination, they appeared to be mud. I've had a trawl through a number of threads and the most common diagnosis for water in the oil seems to be a worn impeller shaft however, this would not explain the mud. I'm guessing that the most probable cause is overuse or poor aiming of a pressure hose. Would I be correct in this? Or any other thoughts? Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 7, 2017 Report Share Posted April 7, 2017 Are you loosing coolant ? Quote Link to comment Share on other sites More sharing options...
tshock250 Posted April 7, 2017 Report Share Posted April 7, 2017 How long has the oil been in? Quote Link to comment Share on other sites More sharing options...
oldgit Posted April 7, 2017 Author Report Share Posted April 7, 2017 (edited) Coolant still full. Oil been in approx one month - around 20 hours, I would guess. Also - have checked carb, air cleaner, filter etc. Anywhere that mud/dirt could have got in. Nothing out of place there. Edited April 7, 2017 by oldgit Quote Link to comment Share on other sites More sharing options...
tshock250 Posted April 7, 2017 Report Share Posted April 7, 2017 (edited) It wont be mud, it can look like it though if its contaminated/old/emulsified. 20 hours is the max I would go to before a change. Edited April 7, 2017 by tshock250 Quote Link to comment Share on other sites More sharing options...
oldgit Posted April 7, 2017 Author Report Share Posted April 7, 2017 OK. Thanks very much, gents. I'll keep an eye on it and change frequently. Quote Link to comment Share on other sites More sharing options...
guys Posted April 8, 2017 Report Share Posted April 8, 2017 Is the breather tube still properly connected and routed as the clear tube in this picture, that's connected to the gearbox in front of the sprocket? http://tuffcitypowersports.com/assets/uploads/images/Other/gg_txt_racing_2015_0061.jpg Quote Link to comment Share on other sites More sharing options...
biffsgasgas Posted April 8, 2017 Report Share Posted April 8, 2017 Your water pump is probably on its way out. There is no oil in or near the cylinder head. --Biff Quote Link to comment Share on other sites More sharing options...
oldgit Posted April 9, 2017 Author Report Share Posted April 9, 2017 On 08/04/2017 at 10:17 AM, guys said: Is the breather tube still properly connected and routed as the clear tube in this picture, that's connected to the gearbox in front of the sprocket? http://tuffcitypowersports.com/assets/uploads/images/Other/gg_txt_racing_2015_0061.jpg Clear tube still connected. No sign of the purple tube - but I guess that's from the Keihin carb and mine's fitted with a Dellorto. I'll have a much closer look tomorrow once the bike's cleaned and dried. Apart from that - done four or five hours over the weekend and new oil is still crystal clear. Hoping it's a one-off but checking out the water pump. Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
