Changing Rookie Crank Seals
tobster
I have never worked on a Rookie. BUT, I have owned 25 dirt bikes and I have never had to split the cases to replace wet side crank seal. In fact, I installed a new seal friday on my sons GG50 while I had the clutch pack out. Just need to lubricate the seal and make sure you press it in straight. Go slow, I used a deep well socket to press the seal in ion the GG50.
Tony P
hi Tony
Thanks for the reassuring answer - hopefully someone who has actually worked on one of these bikes/engines will be able to confirm your answer...presumably you 'just' dig out the old with a screwdriver and then push a new one in. Is there anything to be gained by cooling the seal to help it slip in easier or does that trick only work with bearings?
