GasGas large clear tanks
lee_28
Hi all,
does any one no where the best place/cheapest to get the large clear tank for a gas gas pro?
im also told these need modifying to fit the 17 model, any one any more info?
many thanks in advance
The clear tanks were made to fit Gas Gas bikes with the coil mounted on the left side frame rail. For the last few years the coil is now mounted between the frame rails under the tank, hence why the clear tanks need to be modified to fit those later bikes.  For a direct bolt up on later models get a GG CONTACT tank. Part number BT76001CT-CFW-1
  • 5 weeks later...
Would anyone know if the Contact tank would fit an older 2008 PRO? I believe my PRO frame is built with rectangular tubing, but the coil is mounted between the frame up near the steering head. And I see that there is a factory clear tank for the 2008 PRO on the GG web site (?), but I believe it's ~4x the cost of the Contact tank. :(
Thanks.
Dale
