iconic558 Posted May 9, 2017 Report Share Posted May 9, 2017 Hi guys, looking at my 247C it appears that the only clutch adjustment is at the clutch perch? Is this correct? many thanks Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted May 9, 2017 Report Share Posted May 9, 2017 In fact, there's more points to adjust, like the bronze pusher height, but assuming you still wear the original, everything will be OK. Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 9, 2017 Author Report Share Posted May 9, 2017 Thanks Quote Link to comment Share on other sites More sharing options...
keychange Posted May 9, 2017 Report Share Posted May 9, 2017 Yep the pusher pad (thimble) comes in various lengths --- if you can find them. Be sure not to adjust this so that the pusher is engaged as it will wear out very quickly Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 10, 2017 Author Report Share Posted May 10, 2017 https://www.inmotiontrials.com/product/montesa-cota-clutch-push-pad-10mm/ Found them! Cheers gentleman Quote Link to comment Share on other sites More sharing options...
