wider footrests for Cota 247C
iconic558
The original footrests are pretty pathetic, aren't they?
I use Raceline footrests, from www.motomerlin.co.uk. They are grippy and wide like other modern footrests but fit the single fitting on the Montesa frame - other footrests require the usual U-shaped bracket. I just had to grind the back edge a touch so the footrests sit horizontally. As I recall I used the original Montesa springs.
With some more modification it might even be possible to fit them down and back a bit as per the modern trend by mounting them behind, rather than over, the standard fitting on the frame.
