netley Posted May 10, 2017 Report Share Posted May 10, 2017 I am hoping to have fix my 349 fork leg welded up but on dis-assembly to do a refresh I find there is a small part that fits into the bottom of the spring. In profile it is sort of top hat shaped. One of these is intact and the other is broken. Does anyone have the slightest idea what I'm on about and if so where I can fine replacements? Cheers. Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted May 10, 2017 Report Share Posted May 10, 2017 Yes, I know what you're talking about. Would have thought a local engineering workshop could turn one up on a lathe to match your existing one with little bother. 1 Quote Link to comment Share on other sites More sharing options...
netley Posted May 11, 2017 Author Report Share Posted May 11, 2017 It looks like it was pressed as the metal is thin, maybe 1mm. Quote Link to comment Share on other sites More sharing options...
netley Posted May 13, 2017 Author Report Share Posted May 13, 2017 Apparently the same as Bultaco so called In Motion and they were as patient and helpful as ever. One is on its way. 1 Quote Link to comment Share on other sites More sharing options...
