iconic558 Posted May 12, 2017 Report Share Posted May 12, 2017 My clutch is working just dandy at the moment, no dragging, no slipping in top and neutral is a piece of p*ss to find. If I had to find fault it's a little bit on or off. I believe the 'book' says 10/30 motor oil, but also see that some use ATF, as I do in my Speedy. Any recommendations gentlemen? thanks in advance Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted May 12, 2017 Report Share Posted May 12, 2017 ATF is fine in mine. Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 13, 2017 Author Report Share Posted May 13, 2017 cheers again sir Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 13, 2017 Report Share Posted May 13, 2017 ATF works, but seems to fade when hot. Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 13, 2017 Author Report Share Posted May 13, 2017 4 hours ago, lineaway said: ATF works, but seems to fade when hot. thanks Quote Link to comment Share on other sites More sharing options...
