Ossa Mar rearbrake modification
nivlac123
On 10/19/2017 at 8:26 PM, nivlac123 said:
OK I have verified that my swing arm is still a mk 1. Would anyone know which cable I would need. I have the one with the nipples on both ends and adjuster in the middle. Would I need the one with the threaded rod at the end.
The cable with the threaded rod at the end is the longer cable, therefore suits the longer swingarm. The cable with the adjuster in the 'middle' is the shorter cable and therefore is for the MK1 swingarm.
Thank you Woody I think to problems is I have to much travel of the brake plate arm before the pads engage. Pads are new there was padding on the round brake pivot on the inside of the plate I have just measured the dia of the hub braking surface and that is well within the manual tolerances. Is it normal to pad out to round pivot?
