fstclyz Posted December 5, 2017 Report Share Posted December 5, 2017 Which way to do riders examine sag on these? With or without a rider? Quote Link to comment Share on other sites More sharing options...
oldtrialer Posted December 5, 2017 Report Share Posted December 5, 2017 Without rider. Lift the rear up and see how much it settles down. That's how I did it on my GasGas.. Quote Link to comment Share on other sites More sharing options...
fstclyz Posted December 6, 2017 Report Share Posted December 6, 2017 23 hours ago, oldtrialer said: Without rider. Lift the rear up and see how much it settles down. That's how I did it on my GasGas.. I tried that and it didn't move. I think this bike might be too light for that process. I turned my rear spring preload up a bit from stock but who knows if they are all set the same from the factory. Sitting/standing on the bike, I'm getting about 20% sag front and rear. I don't think we can adjust the fork preload. The OEM 24r rear spring is 650 lbs. Oset has a 750lb spring but there's no conclusive evidence yet on how it works or for what weight of a rider. On my enduro race bikes, we always set sag with the rider and gear on the bike but I'm keeping my mind open on how to setup these trials bikes (and yes I know this isn't really an adult trials bike, I'm just trying to extract as much potential from it as possible). Quote Link to comment Share on other sites More sharing options...
oldtrialer Posted December 6, 2017 Report Share Posted December 6, 2017 My preload adjusting nut was loose at first. I snugged it up so it wouldn't loosen again. I think getting used to the electric quirks is the most important thing. Quote Link to comment Share on other sites More sharing options...
gwhy Posted December 7, 2017 Report Share Posted December 7, 2017 sag should be setup with riders weight i.e with rider onboard and should be around 10-15mm for the rear and it normally higher for the front . bounce about a bit on the bike before taking any measurements.. Quote Link to comment Share on other sites More sharing options...
oldtrialer Posted December 8, 2017 Report Share Posted December 8, 2017 I'm pretty sure the GasGas manual said to lift the rear fender and then see how much it drops. You want a trials bike soft. Most will drop an inch with rider on. Quote Link to comment Share on other sites More sharing options...
gwhy Posted December 8, 2017 Report Share Posted December 8, 2017 Sag is set depending on the weight of a rider . the manual is prob a generic factory setting for the shock. Mountain bike shocks dont have the same dynamics as a mc shock so things will be different. Quote Link to comment Share on other sites More sharing options...
fstclyz Posted December 13, 2017 Report Share Posted December 13, 2017 I added the 3.5" tire like the others which I like. There's a fine line on getting the chain tension right and the tire not to rub but it worked with I think two extra chain links. I also just installed a set of SRAM Code RSC brakes using the stock 180 rotors. PLENTY OF POWER and really nice brake modulation. This is a expensive set at $480 but really one of the best you can buy for a mtn bike brake (two piston caliper). The RSC has adjustable pad engagement which I really love. This bike needed more clinching power, not bigger rotors. I also added the ROX 2" riser but on the fence with that one until I ride it more. FUN bike although I'm still not happy with the delivery of the power at mid throttle. It's too aggressive and not linear enough. I'll work on using the rear brake to control that.... Quote Link to comment Share on other sites More sharing options...
Ron_Luning Posted January 9, 2018 Report Share Posted January 9, 2018 I saw a question about battery life. I made this video to demonstrate: If anyone wants to see something about OSET 24 bikes in photos or video, reply to this thread and I'll see what I can do. I am selling this particular OSET 24, which is in great condition with very little use. Please email me if you want to know more at cyclecrushmoto@gmail.com Quote Link to comment Share on other sites More sharing options...
oldtrialer Posted December 9, 2019 Report Share Posted December 9, 2019 Finally got around to making a new kickstand and mounting bracket. Now I don't have to worry about a gust of wind blowing it over. Also, at my weight (165 lbs), I put a lighter spring on the shock and in the fork. Traction is much improved. 1 Quote Link to comment Share on other sites More sharing options...
Dualta Posted January 28, 2020 Report Share Posted January 28, 2020 (edited) On 1/9/2018 at 11:13 AM, Ron_Luning said: I saw a question about battery life. I made this video to demonstrate: If anyone wants to see something about OSET 24 bikes in photos or video, reply to this thread and I'll see what I can do. I am selling this particular OSET 24, which is in great condition with very little use. Please email me if you want to know more at cyclecrushmoto@gmail.com Cool video. What weight are you, and what power settings were you running on? I’ve seen various videos and read various reviews with widely different times being reported for how long a charge lasts. One guy in Aus reported 13 hours running max power until the low power warning light came on and then he got another six hours. It’s hard to believe, but that’s what he claims. A teenager on YouTube reported one charge lasting “all day”. The Aussie guy’s review. He talked about the battery from 4:05: Edited January 28, 2020 by dualta Quote Link to comment Share on other sites More sharing options...
sectionone Posted January 29, 2020 Report Share Posted January 29, 2020 I've been riding my Oset 24 in my backyard stop and hop style and the battery lasts longer than my body. I can do 3 one hour sessions on one charge. 1 Quote Link to comment Share on other sites More sharing options...
Dualta Posted January 29, 2020 Report Share Posted January 29, 2020 1 hour ago, sectionone said: I've been riding my Oset 24 in my backyard stop and hop style and the battery lasts longer than my body. I can do 3 one hour sessions on one charge. What weight are you, if you don’t mind me asking? Quote Link to comment Share on other sites More sharing options...
sectionone Posted January 30, 2020 Report Share Posted January 30, 2020 55 years old, 5'4", 138lbs. I turn the speed dial down to the start of the red zone for trials and for trail riding everything all the way right. When trail riding the battery can drain quickly but for backyard trials it just sips the juice. 1 Quote Link to comment Share on other sites More sharing options...
Dualta Posted January 30, 2020 Report Share Posted January 30, 2020 14 minutes ago, sectionone said: 55 years old, 5'4", 138lbs. I turn the speed dial down to the start of the red zone for trials and for trail riding everything all the way right. When trail riding the battery can drain quickly but for backyard trials it just sips the juice. That’s a similar weight to me. I like what I’m reading about these bikes. I see one in my near future. Even if my wife doesn’t ? 1 Quote Link to comment Share on other sites More sharing options...
