iconic558 Posted May 20, 2017 Report Share Posted May 20, 2017 Hi guys, my front brake still isn't as hard as I would like. I have noticed that my brake arm is at a poor angle to the where the cable meets it. The arm pulls up and flexes sideways due to this. I also think my brake arm is delaminating and will get it to my welding friend to see if he can beef it up. Maybe bend to out to suit cable and weld plates to it? It is bad angle normal? First trial with the old bus tomorrow so more to follow. Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 20, 2017 Author Report Share Posted May 20, 2017 A picture tells a thousand words....or two thousand in this case. Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 20, 2017 Report Share Posted May 20, 2017 Yes it looks wrong. I'm thinking the cable holder should be on the inside of the mudguard mount and then when you straighten the brake arm, the cable will have a straight pull. I have done as I just described with my Cota 348 which appears to have the same brake hub, arm and mudguard mounting arrangement, and it works very well Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 20, 2017 Author Report Share Posted May 20, 2017 Cheers Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 20, 2017 Author Report Share Posted May 20, 2017 Just had quick look and it looks as if there isn't enough room to place the cable retainer on the onside of the fork leg....odd? Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted May 20, 2017 Report Share Posted May 20, 2017 Could we have more of a side view, to show how things are at the moment? Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 20, 2017 Author Report Share Posted May 20, 2017 Will do guys....more to follow Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 20, 2017 Report Share Posted May 20, 2017 Maybe your mudguard is a bit wider than mine. This shows the arrangement on my 348 Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 21, 2017 Author Report Share Posted May 21, 2017 Wow thats tight....maybe I do have room afterall. Thanks for taking the time out to take that pic' 1 Quote Link to comment Share on other sites More sharing options...
iconic558 Posted May 22, 2017 Author Report Share Posted May 22, 2017 (edited) It does fit on the inside of the fork leg! Well I measured the gap using my vernier and low and behold there was room.....just, to fit the cable retainer on the inside of the fork leg. Angle is now perfect but had to take a nibble out of the mudguard for the cable. That front brake arm is still bugging me though. It seems to be two pieces of tin spot welded in but two places and really needs beefing up. I can still see it flexing and it's super easy to bend. Anyway cheers guys for the help on resolving this one Edited May 22, 2017 by iconic558 Quote Link to comment Share on other sites More sharing options...
manchester uk Posted October 16, 2017 Report Share Posted October 16, 2017 Not sure if your brake arm is an OEM part.... looks like a replacement ...? Also the original run was on the outside of the mudguard stay Quote Link to comment Share on other sites More sharing options...
oldaz Posted November 20, 2017 Report Share Posted November 20, 2017 On 23/05/2017 at 3:39 AM, iconic558 said: It does fit on the inside of the fork leg! Well I measured the gap using my vernier and low and behold there was room.....just, to fit the cable retainer on the inside of the fork leg. Angle is now perfect but had to take a nibble out of the mudguard for the cable. That front brake arm is still bugging me though. It seems to be two pieces of tin spot welded in but two places and really needs beefing up. I can still see it flexing and it's super easy to bend. Anyway cheers guys for the help on resolving this one Sounds like the typical brake arm, mine was made the same way and bent/twisted like yours when I got my bike. The cable retainer had been fitted wrong and the front wheel was in backwards, so plenty of angles were wrong. The brake arms seem strong enough when they are straightened out (takes some doing to get them right) and the cable angles are correct. If I find mine starting to twist under pressure with the angles correct, I'll make new brake arm/s as needed or find stronger alternatives. Quote Link to comment Share on other sites More sharing options...
