diesel2607 Posted June 1, 2017 Report Share Posted June 1, 2017 I have snapped a front spoke on my 2005 rev 3 any idea where to get a replacement spoke and nipple from and what size I would need to get some of the spoke is still stuck in the nipple so unable to measure Quote Link to comment Share on other sites More sharing options...
bilks Posted June 2, 2017 Report Share Posted June 2, 2017 (edited) Try Beta UK.part no 27-241192 size 3x254c 169 27-241193 3x256c 169 Nipple 23-10100 or here. http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x254+Beta&Id_Article=632 http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x256+Beta&Id_Article=633 http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+nut+3+mm&Id_Article=3972 Edited June 2, 2017 by bilks Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted June 2, 2017 Author Report Share Posted June 2, 2017 OK thanks I will get one ordered what's the best way of taking the tyre off that's the part I am most worried about Quote Link to comment Share on other sites More sharing options...
markparrish Posted June 2, 2017 Report Share Posted June 2, 2017 (edited) It's just the same as removing a bicycle tyre (if you know how to do that) - just more effort required and correspondingly bigger tyre levers. There are lots of videos on youtube showing this - mostly rear tyres though, which are tubeless (I just did my rear). I got a pair of cheap levers from eBay which came with some useful plastic rim protectors. Warning - although perfectly strong, my levers had a few rough edges so I filed them off before use. You will also need some tyre soap to make it easier - many use fairy liquid (I did!) but there seems to be quite a debate about its long term effects on alloy rims. Careful not to nick the tube - a very small amount of air inside when re-fitting the tyre can help avoid trapping it. Good luck Mark Edited June 2, 2017 by markparrish spelling tyre! Quote Link to comment Share on other sites More sharing options...
diesel2607 Posted June 3, 2017 Author Report Share Posted June 3, 2017 On 02/06/2017 at 3:06 AM, bilks said: Try Beta UK.part no 27-241192 size 3x254c 169 27-241193 3x256c 169 Nipple 23-10100 or here. http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x254+Beta&Id_Article=632 http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+3x256+Beta&Id_Article=633 http://www.zonetrial.com/ArticleDetail.aspx?langue=E&Modele=Spoke+nut+3+mm&Id_Article=3972 This part no comes back with a spoke for a techno will this same spoke fit 2005 rev 3 Quote Link to comment Share on other sites More sharing options...
bilks Posted June 3, 2017 Report Share Posted June 3, 2017 (edited) Well part no from beta spares list for 2005 Rev 3 yes same as 99 Techno at least.but not 97/98 http://www.betausa.com/sites/default/files/pdf/2012Support/Parts Diagrams/Mototrial/Full Size/2005 Rev 250-270 2 stroke.pdf http://www.betausa.com/sites/default/files/pdf/2012Support/Parts Diagrams/Mototrial/Full Size/1999 Techno 250 2 stroke.pdf Edited June 3, 2017 by bilks Quote Link to comment Share on other sites More sharing options...
