otter237 Posted June 5, 2017 Report Share Posted June 5, 2017 -I check the wooodruff key because i have a problem with switch on my bike, it starts random . I found this ! Woodruff key to advance ignition! WTF I just replaced with an orginal sherco key, but now i don't find anyone chisel mark ! Now the only way is the dial gauge? -Second question is.... What yellow do I have to buy for the '13 frame? Thank you so much!! I Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 5, 2017 Report Share Posted June 5, 2017 From what I can see your woodruff key was 3/4 sheared rather than made that way. Just refit the stator in the same position that it was in, looks like centre of the slot going on the witness marks from the washers Should be pretty close to right Quote Link to comment Share on other sites More sharing options...
otter237 Posted June 6, 2017 Author Report Share Posted June 6, 2017 "This off-set flywheel timing key allows you to advance your ignition timing without modifying your stator or cases" It change the ignition timing maybe of 2 degree. If you tell me "use the old position" i use the old position , thank you ! Old pic: Quote Link to comment Share on other sites More sharing options...
dan williams Posted June 6, 2017 Report Share Posted June 6, 2017 This would work. The key is just for alignment. It isn't what holds the flywheel in position. Ask anyone who didn't use a proper torque wrench to reinstall the flywheel. Quote Link to comment Share on other sites More sharing options...
otter237 Posted June 7, 2017 Author Report Share Posted June 7, 2017 Good, it works ! Thanks Quote Link to comment Share on other sites More sharing options...
