vinnied Posted June 13, 2017 Report Share Posted June 13, 2017 What Size front and rear sprockets for cub, recommended. Quote Link to comment Share on other sites More sharing options...
naichuff Posted June 13, 2017 Report Share Posted June 13, 2017 I use a standard engine and clutch sprocket setup The gear box is 13t and rear is 58t (420chain) but I use a lower sleeve gear and lay shaft gear as the bike was set up for the Pre65 SSDT which has road work The rider tells me the gearing is fine for the sections and moor work 1 Quote Link to comment Share on other sites More sharing options...
b40rt Posted June 13, 2017 Report Share Posted June 13, 2017 2 hours ago, naichuff said: I use a standard engine and clutch sprocket setup The gear box is 13t and rear is 58t (420chain) but I use a lower sleeve gear and lay shaft gear as the bike was set up for the Pre65 SSDT which has road work The rider tells me the gearing is fine for the sections and moor work What is the best gear for bogs ? Quote Link to comment Share on other sites More sharing options...
naichuff Posted June 13, 2017 Report Share Posted June 13, 2017 I think the brakes were wet 1 Quote Link to comment Share on other sites More sharing options...
