mod 99 rebuild
scbond2
trying this for the first time and am struggling twith the kickstart internal gubbins (tech term) esp how you position the ratchet device
hope some one can provide some details that even i can understand!
I have found the easiest way is to hook the spring up then put at least a half turn of the kickstart shaft to pretension the whole thing. Then you have to put the first rachet gear on after the little spring on the shaft from the inside. Then you have to get the gear on the shaft. Make sure you remember that this gear has to hit against the metal bolton plate inside the gearbox. This is the kickstart stop. You might have to do that a couple of times until you get the spring tension correct. If you have a manual just read it and look at the photos. Graham.
