tugg Posted June 16, 2017 Report Share Posted June 16, 2017 Hi just acquired a 2012 ossa tr280i but I have a couple of problems with it , firstly the linkage is showing signs of play ,looks like its coming from the centre bolt on the rocker , where can I buy new bushes and pins , also rear silencer is cracked badly so looks like I need to get that welded , but I'm guessing it will eventually fall apart again . also the rear wheel bearings are shot , does anybody know what size bearing they are ,? thanks in advance. Quote Link to comment Share on other sites More sharing options...
lotus54 Posted June 16, 2017 Report Share Posted June 16, 2017 Where are you located? The bushing are easier to source in Europe it seems. Assuming you are buying in bulk. Trials And Tribulations does have them one by one. I was thinking the early bikes had bushings in the rear wheel? Did they change to bearings by 2012? I have the number written down someplace, but you can get the number off the bearing also. Mark Quote Link to comment Share on other sites More sharing options...
gasserguy Posted June 16, 2017 Report Share Posted June 16, 2017 You can still get parts from the old importer.... http://www.ossauk.co.uk/ Quote Link to comment Share on other sites More sharing options...
