eddie Posted November 28, 2005 Report Share Posted November 28, 2005 Hi, I went to move my 200 GG last night and had oil leaking from the right fork at the bottom of the fork leg. The allen bolt at the bottom of the fork leg was tight. It has not been ridden for about 2 weeks but gets moved often and I have never seen oil on the floor before. It was definitely coming from the bottom of the fork leg. Any ideas?? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted November 28, 2005 Report Share Posted November 28, 2005 I guess the answer would be to take the leg out, turn it upside-down, take the bolt out and check it out. I suppose there should be a sealing washer there. Maybe it was left out. Check for cracks. The possibility of a crack would make it a real bad idea to ride before you check it out. Quote Link to comment Share on other sites More sharing options...
jtt Posted December 2, 2005 Report Share Posted December 2, 2005 Like Charlie said, check that bolt and sealing washer. Probably got a bit of dirt or a filing under the washer and causing the leak. Quote Link to comment Share on other sites More sharing options...
