james n Posted June 24, 2017 Report Share Posted June 24, 2017 74 ty 250 was running great for a year then it started breaking up and when you are accellerating it wont rev up. cleaned carb cleaned points and reset timming any ideas Thanks Jim Quote Link to comment Share on other sites More sharing options...
shakennstirred Posted June 24, 2017 Report Share Posted June 24, 2017 Clean air filter? 1 Quote Link to comment Share on other sites More sharing options...
spen Posted June 24, 2017 Report Share Posted June 24, 2017 Decoke the exhaust..... 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 24, 2017 Report Share Posted June 24, 2017 Plug and condenser. 1 Quote Link to comment Share on other sites More sharing options...
james n Posted June 26, 2017 Author Report Share Posted June 26, 2017 cleaned air filter switched pipes new plug and nothing. it acks as if it has a rev limiter on it Quote Link to comment Share on other sites More sharing options...
spen Posted June 26, 2017 Report Share Posted June 26, 2017 (edited) Exhaust blocked? Carbon build up or been dented? Edited June 26, 2017 by spen Typo... Quote Link to comment Share on other sites More sharing options...
tony27 Posted June 26, 2017 Report Share Posted June 26, 2017 Does the TK carb fitted have the main jet screwed into the float bowl like I suspect, if so replace the o-ring that sits on the bottom of the needle jet as if it is damaged it lets fuel bypass the main jet & it will run very rich 2 Quote Link to comment Share on other sites More sharing options...
Sectioned Posted June 26, 2017 Report Share Posted June 26, 2017 Reeds? Quote Link to comment Share on other sites More sharing options...
james n Posted July 17, 2017 Author Report Share Posted July 17, 2017 Hi again, this isnt my bike I was trying to help a friend get ready for vintage motorcycle days.He ended up borrowing a friends motor. here is alist of what was done. new points ,condenser,coil,air filter and o-ring in carb. and ing side main seal. we also tried a differant ty carb and exshaust we could not get any new reeds.to try. The bike runs great with the air cleaner and the air box lid removed.if you put the air box lid on without the air filter the bike wont rev, if you put the air filter in without the air box lid bike wont rev. take them out and the bike revs fine. Quote Link to comment Share on other sites More sharing options...
motovita Posted July 17, 2017 Report Share Posted July 17, 2017 Were the carb and exhaust from a running TY? Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted July 17, 2017 Report Share Posted July 17, 2017 5 hours ago, james n said: The bike runs great with the air cleaner and the air box lid removed.if you put the air box lid on without the air filter the bike wont rev, if you put the air filter in without the air box lid bike wont rev. take them out and the bike revs fine. Based on this info, it seems logical to conclude that the problem is associated with air intake, not the carb or exhaust or timing. I just looked at my ’74 and confirmed my memory that the air get into the airbox through 2 holes on the left side of the box. These are behind the oil reservoir. If they are completely blocked, the bike will not run. If they are partially blocked, the bike could run at low RPM but not get enough air to run faster. I suspect that something happened to the airbox or the oil tank leaving too small a space for air to get to those intake holes. Good luck. Let us know what you find out. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted August 8, 2018 Report Share Posted August 8, 2018 Can't be sure from your description, but if the engine is blubbering instead of reving when you open the throttle you might have the air bleed screw out too far or have a bad main crank seal leaking which causes a two way vaccum/pressure leak which causes the mixture from the carb to be mixed with too much air which will misfire or just not make much power. That is assuming that the carb is all clean and good with new NON-Ethanol premium fuel and 50-1 synthetic oil mix or equivalent. Quote Link to comment Share on other sites More sharing options...
scifi Posted August 15, 2018 Report Share Posted August 15, 2018 (edited) Sound like it is running too rich at full throttle. You haven't done something daft like clean the main jet out with a twist drill have you? Or perhaps you have put the needle back in the wrong notch. Either way you should have a sooty plug, to confirm it is running rich. Maybe the cure is to reduce the main jet size until it gives the correct performance. edit.... Just had another thought... Is the Cold-Start mechanism working correctly, with no rotting of the rubber seals.? Edited August 15, 2018 by scifi Quote Link to comment Share on other sites More sharing options...
