ducati pick up coil
mudyman
Hi all,
a good friend is in need of help tracing an "after market" pick up coil to replace the old ducati bit.
Any information would be great !
I think its a GG Pro from about 2006 but not sure without asking him again.
Almost any suitably sized inductive type crank or cam position sensor should do, even an ABS sensor. You probably want one with a resistance of between 800 and 1250 Ohms. Takes your to a local motor factor and see what they have. In UK I would compare sensors on Euro Car Parts website.
You will have to adjust / shim the sensor so it is correct distance from flywheel.
You could possibly even rewind your own with fine enamelled copper wire.
