2007 TXT PRO 300
jimbike64
I don't know what the actual compression ratio is on the 300, but imagine it would be around 9:1. Therefore if you used a compression tester screwed into the spark plug hole and kicked the motor over, you would expect to read 14.7 x 9 psi, or approx 130 psi from a healthy top end.
Bye, Peter B.
