b40rt Posted April 1, 2018 Report Share Posted April 1, 2018 11 hours ago, section swept said: Ah but you haven’t allowed for the earths gravitational pull. Then of course air pressure at sea level is 14.7 psi so the higher in altitude you ride the less infinite pressure you will have! A compressed air cylinder would be needed, thus adding weight back so probably weighing more than the conventional braking system.???? "Less infinite" sounds like a biblical term .... Quote Link to comment Share on other sites More sharing options...
section swept Posted April 1, 2018 Report Share Posted April 1, 2018 40 minutes ago, b40rt said: "Less infinite" sounds like a biblical term .... Bibles are quite a weighty tome as well! Quote Link to comment Share on other sites More sharing options...
