2004 Scorpa SY250 Questions
thehighlander123
As above, just picked one up a week ago.
Anyway,  I don't know a great deal about bikes - Cars are my thing.
1 - Front brake squeel is terrible, it's so loud and also the brake is not sharp when you pull it on.
2 - Clutch drag - When riding and i pull the clutch in I can still feel the bike wanting to pull forward.
Are these common issues?
Remove your pads and check them also check your disc i had same problem on a Gas Gas i used to own,Pads might be worn or contaminated.also there is also a clutch adjusting screw just under the mid box for your clutch.well there is on my 2007 might be a good idea to change your gearbox oil if you have just bought it.
Edited by bilks
Thanks Biks,
Will get a good look at it this weekend.
Was thinking of doing a pad change as they're cheap anyway.
