1980s Forks
europa
I am rebuilding a JCM 240 Europa from the late 80s. when I was replacing the fork seals ( I believe these should be Marzocchi ) I found the internals of the 2 forks are completely different. is this normal & does anyone have a parts diagram or any maintenance info on these forks?
You will probably realise it from the parts diagram but please note the seals are different in each leg. From memory one side has one wide seal the other  two thinner ones, only one side has a retaining circlip also.
Edited by topline620
