efi64 Posted December 1, 2005 Report Share Posted December 1, 2005 Hi! I have a 1998 290 Easy. I love the bike but the gear is very notchy and the clutch drags badly, especially when cold. Anyone knows what type of oil or what oil viscosity should I use for better clutch and gear action ? I understand that only three out of the five clutch spring are used in this bike. Would adding the missing two springs in the pressure plate have any negative effects on a bike that is used solely for trail riding ? Thanks, Efi. Quote Link to comment Share on other sites More sharing options...
scorpa-usa Posted December 26, 2005 Report Share Posted December 26, 2005 Dextron 111 ATF works very well with the easy clutch. It is important to only use 450cc and the clutch should not drag if everything is within specs. Quote Link to comment Share on other sites More sharing options...
