lewis Posted December 1, 2005 Report Share Posted December 1, 2005 just fitted new bars on 4rt ,throttle cable seems tight now ,on full right lock cable is pulling anyone else had same problem ,how did you get round it? Quote Link to comment Share on other sites More sharing options...
munch Posted December 1, 2005 Report Share Posted December 1, 2005 whats different about the bars? Quote Link to comment Share on other sites More sharing options...
lewis Posted December 1, 2005 Author Report Share Posted December 1, 2005 about 18mm in length. Quote Link to comment Share on other sites More sharing options...
masso Posted December 1, 2005 Report Share Posted December 1, 2005 dude.............go back to stock bars!!! a 315 throttle assebley will help the problem. also get a 315 air filter, they breath much better!!! Quote Link to comment Share on other sites More sharing options...
lewis Posted December 2, 2005 Author Report Share Posted December 2, 2005 its just a standard set of renthals ive put on ,see the bloke who had it before me cut a bit of the bars ,to narrow for me ,thats why i cant understand why it would make cable tight. Quote Link to comment Share on other sites More sharing options...
wardo Posted December 2, 2005 Report Share Posted December 2, 2005 I too have had problems with the throttle cable routing. When I turn full lock right the revs climbed. I rerouted the cable behind the bars, that helped some, but didn't totally cure the problem. I need to leave a miniscule amount of slack in the cable, something I usually don't like, but have adapted to. Maybe a total reroute is in order.... Wardo Quote Link to comment Share on other sites More sharing options...
lewis Posted December 2, 2005 Author Report Share Posted December 2, 2005 just spoke to sandifords ,turns out the **** that had it before me routed cable to come out of left side of tank ,ive now run cable up the right hand side of frame and coming out right hand side of tank ,sorted !! thanks for replys. Quote Link to comment Share on other sites More sharing options...
