pmk Posted August 2, 2017 Report Share Posted August 2, 2017 Since the Department of Motor Vehicles allowed me to get a street legal tag for my Resto Mod 73 OSSA MAR, it just seems correct to have a speedometer. I do not have the wheel driven type that mounts to the fork leg. I do have on hand an ICO Checkmate enduro computer, but consider it may be a bit cumbersome and is overkill on functions. Considering using a bicycle computer. Curious what brands and models others may have used. Is it possible to use a wieless type, or will the ignition cause issues? Quote Link to comment Share on other sites More sharing options...
naichuff Posted August 2, 2017 Report Share Posted August 2, 2017 I have used several different types Currently use a Catseye Enduro on the Beta and Cub both are hard wired type not wireless type Did try a wireless one but not a success Tried another make but it would have to be reset after hitting a bump 1 Quote Link to comment Share on other sites More sharing options...
chaser Posted August 2, 2017 Report Share Posted August 2, 2017 Bought a new Beta a few months ago and a bicycle computer was supplied as part of the `road legal` kit. Quote Link to comment Share on other sites More sharing options...
pmk Posted August 2, 2017 Author Report Share Posted August 2, 2017 53 minutes ago, chaser said: Bought a new Beta a few months ago and a bicycle computer was supplied as part of the `road legal` kit. Was the Beta a wired or wireless computer. Do you recall what brand? Quote Link to comment Share on other sites More sharing options...
pmk Posted August 2, 2017 Author Report Share Posted August 2, 2017 1 hour ago, naichuff said: I have used several different types Currently use a Catseye Enduro on the Beta and Cub both are hard wired type not wireless type Did try a wireless one but not a success Tried another make but it would have to be reset after hitting a bump Just went through some mtb stuff I have. Tried to install a wired Cateye. Looks as though the movement of the brake cable will be too much for the wires. Do you have any photos you could share, of how you installed it on the Beta. Quote Link to comment Share on other sites More sharing options...
dannybee Posted August 2, 2017 Report Share Posted August 2, 2017 I used to run a wired one on my road bike , First attempt was a basic one which seemed fine but stopped working at 50mph so I scoured the net and swapped to a wired Sigma BC 5.12 from Halfords recommended by kit car owners and apparently good up to 200mph so you should be fine, Easy to wire in use and setup. Unclips from cradle and has time and odo also tested with GPS and very accurate Hope that helps Quote Link to comment Share on other sites More sharing options...
naichuff Posted August 2, 2017 Report Share Posted August 2, 2017 1 hour ago, pmk said: Just went through some mtb stuff I have. Tried to install a wired Cateye. Looks as though the movement of the brake cable will be too much for the wires. Do you have any photos you could share, of how you installed it on the Beta. Yes the cable is on the short side My speedo is fitted between the clamps on the handle bar brace The cub was mounted the same but it was lost when the rider went over the bars in a bog I had to replace it Try to fit the sender/magnet as high up the fork leg as possible Quote Link to comment Share on other sites More sharing options...
robido Posted August 2, 2017 Report Share Posted August 2, 2017 I use a garmin edge GPS cycle computer. no wires works great. Have two mounts so I can swap back to mtb easily. Got it on line cheap as new model had come out Quote Link to comment Share on other sites More sharing options...
tony27 Posted August 2, 2017 Report Share Posted August 2, 2017 Beta used to have bicycle type units mounted into the top of the fuel tank, they were hardwired from the rear wheel Quote Link to comment Share on other sites More sharing options...
pmk Posted August 3, 2017 Author Report Share Posted August 3, 2017 4 hours ago, robido said: I use a garmin edge GPS cycle computer. no wires works great. Have two mounts so I can swap back to mtb easily. Got it on line cheap as new model had come out That method makes it simple, though more expensive. A very good option though. I had a look at GPS bicycle computers, yes there are some lesser brands for less money. Need to ask my bicycle friends if they have something no longer used. Quote Link to comment Share on other sites More sharing options...
pmk Posted August 3, 2017 Author Report Share Posted August 3, 2017 4 hours ago, naichuff said: Yes the cable is on the short side My speedo is fitted between the clamps on the handle bar brace The cub was mounted the same but it was lost when the rider went over the bars in a bog I had to replace it Try to fit the sender/magnet as high up the fork leg as possible I had mounted the computer I dug out of my bicycle stuff. On the OSSA it needed to mount to the left of the left side bar mount. In regards to the magnet and pickup, normally the gap must be pretty close for it to operate. With the sensor nearer the top of the fork leg, how were you able to get the magnet close enough to work. Quote Link to comment Share on other sites More sharing options...
lerk Posted August 3, 2017 Report Share Posted August 3, 2017 Have a look at the Harmon edge 20. a tiny unit and fairly cheap for a gps! Quote Link to comment Share on other sites More sharing options...
lerk Posted August 3, 2017 Report Share Posted August 3, 2017 Garmin even! 1 Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 3, 2017 Report Share Posted August 3, 2017 I use a wireless one that cost less than ten pounds (whatever that may be in dollars) from Lidl (a German supermarket brand in the UK). Works fine with sender halfway up the slider.and screen on bars. No need to buy an expensive Cateye etc. Quote Link to comment Share on other sites More sharing options...
dannybee Posted August 3, 2017 Report Share Posted August 3, 2017 My current road bike Speedo over reads and I like to know how fast I am going accurately so I use a old mobile phone with a god Speedo app , Reacts surprising quickly but you have to keep charging it so the bicycle Speedo is the better fit and forgot method. Quote Link to comment Share on other sites More sharing options...
