pmk Posted August 3, 2017 Author Report Share Posted August 3, 2017 On 8/3/2017 at 7:18 AM, 2stroke4stroke said: I use a wireless one that cost less than ten pounds (whatever that may be in dollars) from Lidl (a German supermarket brand in the UK). Works fine with sender halfway up the slider.and screen on bars. No need to buy an expensive Cateye etc. Expand Took a little bit of Google search effort, but no big deal. These computers you mentioned are known as Bikemate brand, and here in the USA are carried by Aldi stores. My thought is Lidl and Aldi may be the same company or related. While traveling a couple of years ago, we did pick up some items in Aldi while in Ireland. Locally, Aldi has a store very close to home. On a downside, Aldi built the warehouse and distribution facility very close to home, and in doing so, tore down a large wooded area I used as a riding area. Quote Link to comment Share on other sites More sharing options...
cascao Posted August 3, 2017 Report Share Posted August 3, 2017 Have a cheap wired cateye on mine.. Not dificult to install, just keep wire with brake hose. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 3, 2017 Report Share Posted August 3, 2017 On 8/3/2017 at 10:37 AM, pmk said: Took a little bit of Google search effort, but no big deal. These computers you mentioned are known as Bikemate brand, and here in the USA are carried by Aldi stores. My thought is Lidl and Aldi may be the same company or related. While traveling a couple of years ago, we did pick up some items in Aldi while in Ireland. Locally, Aldi has a store very close to home. On a downside, Aldi built the warehouse and distribution facility very close to home, and in doing so, tore down a large wooded area I used as a riding area. Expand Related in as much as two herren set up in business after the war, can't recall if Lidl or Aldi. There was a later schism resulting in the other name. Quote Link to comment Share on other sites More sharing options...
pmk Posted August 3, 2017 Author Report Share Posted August 3, 2017 On 8/3/2017 at 4:08 PM, cascao said: Have a cheap wired cateye on mine.. Not dificult to install, just keep wire with brake hose. Expand I saw your photo in another section, I think the machined parts topic. This being a vintage machine, the front brake is cable operated and snakes around a bit. Also, how did you mount the sensor close enough to the magnet on the wheel. Do you have a photo of the fork and wheel setup. Quote Link to comment Share on other sites More sharing options...
cascao Posted August 4, 2017 Report Share Posted August 4, 2017 ßFrom the top, the speedodometer cable must start close to the brake master cylinder where there few hose movement. Going down with (electic tape) brake hose untill slave cylinder where the sensor was glued with silicone. In weekend I can take a photo if you want. Quote Link to comment Share on other sites More sharing options...
chaser Posted August 4, 2017 Report Share Posted August 4, 2017 On 8/2/2017 at 7:13 PM, pmk said: Was the Beta a wired or wireless computer. Do you recall what brand? Expand It looks like a cheapo wired unit, personally I would try and get the wireless kit. Quote Link to comment Share on other sites More sharing options...
pmk Posted August 5, 2017 Author Report Share Posted August 5, 2017 Had a look at how Trailtech does the sensor and magnet install. They glue the magnet to the hub and position the sensor on the brake cable. This is for cable operated drum brakes same as the OSSA MAR of mine. Downside, the Cateye computer I have would need the wires extended, or I need to find a long wire kit. Not really wanting to splice the harness. Done it before on bicycles and those wires are tiny. Need to get by Aldi and see the wireless one they offer. Quote Link to comment Share on other sites More sharing options...
