metisse Posted August 3, 2017 Report Share Posted August 3, 2017 I have been asked by a French chum, who is building a Trifield, if I could find out the gear box ratios, and also the sprocket sizes that people in the UK use. Also once found, who could furnish such items. Appriciate any help as he hope to ride in Scotland next year, after struggling a little on his big Terrot. Merci. Quote Link to comment Share on other sites More sharing options...
andrewmorpeth Posted August 3, 2017 Report Share Posted August 3, 2017 Tell him not to bother! He needs a drayton bantam or cub any year model from 2013-2018!! 2 Quote Link to comment Share on other sites More sharing options...
beno41 Posted August 3, 2017 Report Share Posted August 3, 2017 I have a 16 tooth engine sprocket and 15 tooth gearbox supplied by D & C Classics 48 teeth on cub rear. using 520 Standard chain. heavy chain catches on the gearbox casing. gear ratios STD. Quote Link to comment Share on other sites More sharing options...
laird387a Posted August 3, 2017 Report Share Posted August 3, 2017 7 hours ago, beno41 said: I have a 16 tooth engine sprocket and 15 tooth gearbox supplied by D & C Classics 48 teeth on cub rear. using 520 Standard chain. heavy chain catches on the gearbox casing. gear ratios STD. Trifield is a twin motor in a Crusader frame so Cub detail not relevant Quote Link to comment Share on other sites More sharing options...
collyolly Posted August 3, 2017 Report Share Posted August 3, 2017 He maybe referring to the use of a cub hub. Quote Link to comment Share on other sites More sharing options...
