darrenatcowes Posted August 6, 2017 Report Share Posted August 6, 2017 Hello , I've recently purchased a 2006 4RT and noticed that the air box has a spigot on the bottom with a hole through it. I guess this is to let water out, but should it have a pipe or something attached to it? Many thanks. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 6, 2017 Report Share Posted August 6, 2017 (edited) I would expect a short clear tube that is plugged or stoppered in some way. This is used to let you know if your getting oil or water in the air box as well as to drain it out if you do. However, if it doesn't have the tube your pulling in dirty air from it and I would cap it off with something and check it every time you clean your air filter if you can't find a clear tube that would work. Edited August 6, 2017 by jonnyc21 Quote Link to comment Share on other sites More sharing options...
darrenatcowes Posted August 7, 2017 Author Report Share Posted August 7, 2017 11 hours ago, jonnyc21 said: I would expect a short clear tube that is plugged or stoppered in some way. This is used to let you know if your getting oil or water in the air box as well as to drain it out if you do. However, if it doesn't have the tube your pulling in dirty air from it and I would cap it off with something and check it every time you clean your air filter if you can't find a clear tube that would work. Thats what I thought , surely a filter with a large ish hole in it can't be much of a filter ! Its not mentioned in the hand book?? I'd have thought there should be some kind of device on the end. ?? Some one must know. I'll keep digging. Thanks jonnyc21. Quote Link to comment Share on other sites More sharing options...
on it Posted August 7, 2017 Report Share Posted August 7, 2017 here you go out of parts book -------- 17358-nn-2000 tube drain & 15707-634-000 clip breather job done Quote Link to comment Share on other sites More sharing options...
darrenatcowes Posted August 7, 2017 Author Report Share Posted August 7, 2017 2 hours ago, on it said: here you go out of parts book -------- 17358-nn-2000 tube drain & 15707-634-000 clip breather job done Nice one! Thank you. Quote Link to comment Share on other sites More sharing options...
darrenatcowes Posted August 7, 2017 Author Report Share Posted August 7, 2017 Just found the parts list in the back of the manual! Did say I've only just got the bike. Looks like its supposed to be blanked off unless you want to drain it. Many thanks . Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 7, 2017 Report Share Posted August 7, 2017 Ya checked my 07 this morning and have one... though so. Good find "on it". Quote Link to comment Share on other sites More sharing options...
