ukmatador Posted August 8, 2017 Report Share Posted August 8, 2017 1969 MK3 Matador. What are the correct tank badges for this model and year? I have seen thin transfer type and thick 'squashy' ones. John Quote Link to comment Share on other sites More sharing options...
matador107 Posted August 8, 2017 Report Share Posted August 8, 2017 Hello, the originals would have been a design of solid Perspex type of plastic, these days I would think the alternative would be the soft ones about 50 mm ?? In diameter. 1 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 8, 2017 Report Share Posted August 8, 2017 The modern ones are much more crash resistant, but use a decent adhesive. Some modern ones come with a pressure-sensitive adhesive that does not work well when confronted with petrol, heat and vibration Quote Link to comment Share on other sites More sharing options...
twinnshock Posted August 8, 2017 Report Share Posted August 8, 2017 I know nothing about Matador's so obviously well qualified to answer this question. Are we sure that a 1969 bike would have the plastic/perspex badges? My 1971 Sherpa has the sticker thin transfer type badges and I would have thought that an earlier production bike/model would use this type of badge. My model 10 (1965) has thin metal badges just to confuse the issue even further. Stuart 1 Quote Link to comment Share on other sites More sharing options...
sherpa325 Posted August 9, 2017 Report Share Posted August 9, 2017 I am not a Matador expert either, but I am pretty sure the thicker poly type round tank stickers came out on around 1974 or thereabouts, prior to that all the Bulllys I remember seeing had the flat standard sticker type. 2 Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 9, 2017 Report Share Posted August 9, 2017 (edited) My memory is that the thin flat stickers were all you could buy at Frasers as replacements in the early and mid 1970s Edited August 9, 2017 by feetupfun fixing mistake Quote Link to comment Share on other sites More sharing options...
feetupfun Posted August 9, 2017 Report Share Posted August 9, 2017 This shows the thin flat sticker I bought in 1975 when I repainted this M99 Alpina 2 Quote Link to comment Share on other sites More sharing options...
ukmatador Posted August 9, 2017 Author Report Share Posted August 9, 2017 Thanks for the response guys. I see Inmotion do the thin one so thats the way I will go. Just trying to tidy up a scruffy original bike so the question is slightly academic but thought might as well use the right ones if available. Next job is to sort the wiring out for the direct lighting. I see there is no side/parking light facility just dip and full beam. Will it pass a UK MOT like that? Quote Link to comment Share on other sites More sharing options...
