deb Posted August 10, 2017 Report Share Posted August 10, 2017 Where can you find handlebar risers for a montesa? Bar goes from 7/8" to 1 and 1/8". Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 10, 2017 Report Share Posted August 10, 2017 I would recommend a set of high bend bars instead of risers if possible especially on a Montesa with the position of the bar clamps. Got a ride on an 05 4RT with a set of high bars and it was way nicer than the Sherco I took a spin on with risers.. Just my personal recommendation. 1 Quote Link to comment Share on other sites More sharing options...
deb Posted August 10, 2017 Author Report Share Posted August 10, 2017 Where do you recommend buying these bars? Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 10, 2017 Report Share Posted August 10, 2017 In the US you can get them from Stu at http://jackscycles.com/OnlineStore.html, or http://lewisportusa.com/. There are a few other places but I would try them first as they have them listed, where others could order them Jacks or LewisportUSA might have them in stock. In the UK I would check https://jbanyeres.com/en/ first or maybe http://handdracing.com/. but not really sure if they have them as I am in the US and have only ordered a few custom bits from both. Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted August 10, 2017 Report Share Posted August 10, 2017 Oh, and most bikes I have seen use 4.5" or 5" bars so 5.5" or 6" would be your top end. I know Jitsie makes up to 6"... Quote Link to comment Share on other sites More sharing options...
collyolly Posted August 11, 2017 Report Share Posted August 11, 2017 I recently put a set of 5" bars on my GasGas and it was well worth it, only problem encountered was the throttle cable was too short using the original routing so had to play around with that. Quote Link to comment Share on other sites More sharing options...
