paulconstruction15 Posted August 16, 2017 Report Share Posted August 16, 2017 2016 Sherco ST300 Factory and ST125 factory Sure I'm correct but can I fill clutch reservoir with dot 4 same as brakes front and rear. Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted August 17, 2017 Report Share Posted August 17, 2017 It would seem highly unlikely that they would use different fluids on one bike. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted August 17, 2017 Report Share Posted August 17, 2017 Does it not say what type of fluid to use on the reservoir cap? Quote Link to comment Share on other sites More sharing options...
cascao Posted August 18, 2017 Report Share Posted August 18, 2017 If gasket is green, probably it uses mineral oil. If you put a drop of the original oil in water and it get white and mix, its dot. Quote Link to comment Share on other sites More sharing options...
cabby Posted September 30, 2017 Report Share Posted September 30, 2017 2017 uses mineral oil in the clutch and dot 4 in the brake. Apologies for the thread revival but I was doing a search for my own benefit and it tells you on the cap lids. Quote Link to comment Share on other sites More sharing options...
