Knocking front wheel
diesel2607
Hi just been out on my bike and felt the front wheel was knocking when I have the front brake on and gently push the bike forward and backwards you can see the brake disk is still but the wheel is moving causing a knocking feeling
Does anyone know what could be causing this I had front wheel off and only have one washer on the brake disk side between the fork and the spacer not sure if this could cause the problem or if I am meant to have anotger washer the other side
Any help with this would be great
It sounds like it could be the 'top hat' washers that go through the disk are worn.
Really really badly worn wheel bearings..
Or it could be your steering head bearings, but then the front wheel wouldn't move slightly.
If floating disc then try some silicon on the top hat spacers to take out some play.
Check non of the disc bolts have come loose catching the fork/caliper as tyre goes round.
as other say -check wheel bearings and head bearing etc
