To much petrol
grim
Works perfectly for 30 minutes, then it starts to explode in the exhaust system. Loses all the power and stops.
The engine is warm after a few minutes, so heat is probably not the problem. The spark plug is full of soot / black.
Since it works well without problems for 30 minutes, we think everything mechanical is fine (nozzle, gas pump, etc.). We have cleaned the connection to ECU, Checked all cables ++
Has anyone experience a similar problem?. Or have any idea what can result in a problem like this?
On 27.8.2017 at 8:15 AM, jimmyl said:
Does it start again after o few mins stopped?
When it starts playing up does it die on full throttle but ok on tick over- then gradualllg get worse when you appply the throttle?
Yes, that sounds right.
