leosantanalg Posted August 31, 2017 Report Share Posted August 31, 2017 I know that this is a very advanced technique and most of people can only dream about it, but I just wanna make sure I m on the right track! I can do several complete stops while wheeling like slow holding pressure, lets say 7-8 on a good run. I m not fully controlling the direction but I m also trying to stop for as long as possible each time. My questions are: What gear should I be training this?? I usually use 1st. it seems easier to bring the nose up and requires less distance... anyone out there that hops well on the rear? what gear do you use? is there any terrain I should look for?? like, I thought about few small 4" diameter logs lined up just far enough. or just a plain steep terrain with traction would be better?? Thanks all Quote Link to comment Share on other sites More sharing options...
heffergm Posted August 31, 2017 Report Share Posted August 31, 2017 (edited) First gear. It's easier to learn if you find a small incline/hill and point yourself up it. You want to do everything in the 'seated' position: knees bent. Bring the front up from a dead stop, otherwise you're carrying too much speed, rear brake to stop, compress into it with your legs, then pop the clutch and sort of push your feet out in front of you. If you watch any of the pros do it you'll sort of see what I'm trying to describe. I still can't do it, but I'm getting closer. Edited August 31, 2017 by heffergm 1 Quote Link to comment Share on other sites More sharing options...
heffergm Posted September 1, 2017 Report Share Posted September 1, 2017 You don't need a pro to answer the question... there are plenty of guys around that ride at the advanced/expert club level that can show you. 1 Quote Link to comment Share on other sites More sharing options...
leosantanalg Posted September 2, 2017 Author Report Share Posted September 2, 2017 On 9/1/2017 at 7:25 AM, heffergm said: You don't need a pro to answer the question... there are plenty of guys around that ride at the advanced/expert club level that can show you. I should have said expert! Instead pro!! Absolutely. Noted Quote Link to comment Share on other sites More sharing options...
