drca Posted September 1, 2017 Report Share Posted September 1, 2017 Hi: I scored a pair Keihin PKW 28 from a motocross racer for cheap and I am going to use one to do a conversion on the Fantic 300 I am building up. Since I'll have a spare one, I was wondering if it's worth doing the conversion on my 2013 250 TXT Pro too? What are the pro's and con's and what other parts do I need? Thanks. DC Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 1, 2017 Report Share Posted September 1, 2017 Intake manifold and throttle cable. That carb you are getting will need going through. Quote Link to comment Share on other sites More sharing options...
drca Posted September 1, 2017 Author Report Share Posted September 1, 2017 1 minute ago, lineaway said: Intake manifold and throttle cable. That carb you are getting will need going through. Thanks! Where can I get the intake manifold (is it the one off the Raga?)? The carbs are actually close to new (Kawasaki factory supported mini top level racer moved to bigger bike and his dad was liquidating his stock of parts). Now... What's the magic jetting for the TXT 250 (main, pilot, needle and slide)? Denis Quote Link to comment Share on other sites More sharing options...
