Rev3 Jetting help
trialmarc
Hello!
The bike is 2000 Rev3 2T 250 2T which was living at 5800ft (1750 meter) elevation and it ran just fine during test ride at that elevation. The bike now lives at sea level, and it was running fine as-is for about 4 rides. Now the bike is hard to start, so I took a look the spark plug  -- it was wet, dark and the bike refuses to start many times. If I clean the spark plug thoroughly, bike starts fine and the issue repeats after few rides.
Being new to trials bikes and two strokes, I may be facing a jetting issue that I am hoping someone can help me with. Few forum searches say recommended pilot jet is 30 or 27.5. The carb is Mikuni and I am not sure of the current pilot size.
I will be taking out the carb soon, and if you have recommendation on mainjet/pilotjet/airscrew for a newbie like me, I would really appreciate it.
@lineaway thanks. Are the Mikuni jets model specific? i see some listings on Ebay but was wondering if I need to be aware of the Mikuni carb model that the bike uses which I could not find upon cursory look at the bike.
@copemech: sure will do, thanks.
@lineaway, apologies, I should have been clearer in my request.
If have to buy new pilot and main jet, should i worry about fitment to a specific Mikuni carburetor model? Is there a Mikuni model number for 2000 Beta rev3 2T? I did not find in manuals and I didn't see it on the carb.
Cheers.
Lineaway is correct. Also what oil/fuel mixture are you using? If you are like most new trials guys you are throwing far too much oil in. Modern water-cooled, plated-cylinder bikes are quite happy at 80:1 and a lot of real plonkers (riders who don’t race between sections) are fine at 100:1. I think the injected bikes run even higher ratios. It’s been many years since I’ve seen an oil related failure in a trials engine.
Carb is VM26-208 to be specific but that’s an OEM number  so the generic VM26 will get you to the right place. There is a Mikuni thread pinned to the Beta forum chock full of good info.
Despite what some say it is a good card that provided years of good performance on my many Betas.
Edited by dan williams
Thank you @klonheadd and @danwilliams. I have already ordered the 27.5 pilot!
Expand
Initially it was 65:1 which i based it on the Beta manual. Per recommendation from fellow riders, I am currently at 80:1. Since I also do some single tracks and ride along fire roads to access those single tracks, I will stick to 80:1.
Expand
Out of curiosity, how does one get to know the carb model? With dirt bikes, things were pretty simple - the manual would say the carb model :) I do miss the attention to details of Honda manuals.
Currently I have to stick with 2002 or prior models so I can ride year round (green/red sticker BS from Socialist Republic of California)
Expand
Ok will do.
 Knowing the carb model does nothing for your search. You could of taken your existing jets to any motorcycle shop and either they would have them or could order them. Googling Mikuni short hex takes about 10 seconds. By the way did you replace the plug yet as that might have been your real problem. Info at http://www.betausa.com/content/support
  • 2 weeks later...
I’m all for fine tuning but at some point you just have to ride the damn thing. You should be pretty close at this point. You have all the baseline stuff. Any fine tuning from here on is ride, tweak, ride, tweak.... only you can say the bike is tuned properly for you. On my ‘13 I spent many hours fettling with the carb and eventually went back to stock on the pilot and one size down on the main. On the older bikes 27.5  pilot always worked and the main depended on the nature of the bike as Beta tuning is variable year to year.
Go out and play for a bit.
