thall1 Posted September 28, 2017 Report Share Posted September 28, 2017 im only getting 2volts at the fan....its running but very slowly.....and engine overheats ive had a look at the wiring diagram on line but cant quite make it out...its not very readable - any one got a better copy? Anyone got any ideas where the voltage is going? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted September 29, 2017 Report Share Posted September 29, 2017 A common cause for slow fan is fan rubbing against something. You didn't say if the 2 Volts is with the fan connected or not. Test for open circuit voltage to see if it is a fan problem or a power supply problem. Quote Link to comment Share on other sites More sharing options...
lineaway Posted September 29, 2017 Report Share Posted September 29, 2017 So what happened with wiring the headlight? Quote Link to comment Share on other sites More sharing options...
thall1 Posted September 29, 2017 Author Report Share Posted September 29, 2017 Fan isn't rubbing...if I put a 12volt supply on it then runs ok nice and smooth.....2v is from the fan connection on the loom side....I also have 2 volts from the redundant lighting connections. The 'loop' that was connected to the front light connector has been removed. Any ideas which wires to use to check the regulator output?...ive had a look at the drawing on line and cant really make it out Quote Link to comment Share on other sites More sharing options...
chappo Posted September 29, 2017 Report Share Posted September 29, 2017 Had the same problem with my 2016 Evo 4T last week , fan running but very slowly. Took rear mudguard off and one of the plastic connectors that are above the carb had come lose ,but not separated, just making partial contact, sprayed with contact cleaner pushed it back together and the fan ran at normal speed again. 1 Quote Link to comment Share on other sites More sharing options...
portman Posted September 29, 2017 Report Share Posted September 29, 2017 Thall1 Don't know where you have got your diagrams from but https://www.betausa.com/content/support is a very good source. The owner's manuals have wiring diagrams. The earlier ones were poorly reproduced, but if you look at 2014 onwards they are much easier to read. Unless you have indicators etc fitted I suggest you look within each manual for the simplified "race" version, which cuts things down to basics. The "homologated" diagrams are more complex and show handlebar light switches, etc, which most of us don't have. If you go back to the 2013 manual, on page 66 it gives some resistance readings for doing a generator check. This might also help. I don't think they've changed things much over the years, although I may be wrong regards the last couple of years (the regulator rectifier may have changed spec and been moved, not sure). You mentioned in another thread that some lighting wires had been looped together. This might have fried the generator and/or the regulator/rectifier, but you may be lucky. It may be a simple connector problem, as chappo experienced. Quote Link to comment Share on other sites More sharing options...
thall1 Posted September 29, 2017 Author Report Share Posted September 29, 2017 thanks guys....just managed to get into the back of the rectifier and there is only 2 volts output.....new one on order....the bike starts and runs fine so stator side is ok Quote Link to comment Share on other sites More sharing options...
huski Posted September 29, 2017 Report Share Posted September 29, 2017 What voltage do you get in to the rectifier?The stator has different coils for the ignition and the ancillaries.The rectifier converts AC to DC current only,might be worth checking the connections Quote Link to comment Share on other sites More sharing options...
thall1 Posted September 30, 2017 Author Report Share Posted September 30, 2017 just checked the stator, the 'service power supply' ohm reading of 0.6 ohm doesn't appear to be there....looks like this could be the problem...? Quote Link to comment Share on other sites More sharing options...
thall1 Posted September 30, 2017 Author Report Share Posted September 30, 2017 ALL FIXED!!...stator turned out ok...dodgy meter probe threw me off line!...fitted a second regulator/rectifier but still didn't get 12v....had the bike running and for some reason I disconnected the fuel solenoid.....revs went up slightly and the meter read 10.5v!! thanks for all your replies! Quote Link to comment Share on other sites More sharing options...
